shnurok89 Posted October 14, 2008 Share Posted October 14, 2008 i just bought these doors and my buddy at the shop said there are going to be gaps and and he will need to rewire everything http://carlambodoors.com/0306-accord-bolto...54ada88c15495c9 can someone please help me find a guide so i can get a second opinion i want to print out that guide and show it to my mechanic and see if it differs... he says he'll need to cut all the wires Link to comment Share on other sites More sharing options...
airjordan223 Posted October 14, 2008 Share Posted October 14, 2008 yes you need to cut the wires and make them longer because with the lambo doors, it opens farther away. Link to comment Share on other sites More sharing options...
Jesterlyone Posted October 15, 2008 Share Posted October 15, 2008 i just bought these doors and my buddy at the shop said there are going to be gaps and and he will need to rewire everything http://carlambodoors.com/0306-accord-bolto...54ada88c15495c9 can someone please help me find a guide so i can get a second opinion i want to print out that guide and show it to my mechanic and see if it differs... he says he'll need to cut all the wires Another option is multi pin connector things. I don't know how to explain it but I'll look for the link. It's a plate with pads that mounts in the door jamb and another plate with spring loaded pin that mounts in the door. When the door is closed the pins make contact with the pads and the wires are "whole", when the door opens the pins loose contact so the wires are "broken". You don't use any of the power in the door when it is open so there is no problem and you don't have an unsightly amount of wire hanging from the door. Link to comment Share on other sites More sharing options...
Jesterlyone Posted October 16, 2008 Share Posted October 16, 2008 Another option is multi pin connector things. I don't know how to explain it but I'll look for the link. It's a plate with pads that mounts in the door jamb and another plate with spring loaded pin that mounts in the door. When the door is closed the pins make contact with the pads and the wires are "whole", when the door opens the pins loose contact so the wires are "broken". You don't use any of the power in the door when it is open so there is no problem and you don't have an unsightly amount of wire hanging from the door. Hey here's what I was talking about. Contact thingys Link to comment Share on other sites More sharing options...
shnurok89 Posted October 17, 2008 Author Share Posted October 17, 2008 Hey here's what I was talking about.Contact thingys holy crap, thank you that was extremely helpful... and they are pretty freakin cheap 2 Link to comment Share on other sites More sharing options...
