James Nguyen Posted April 18, 2008 Share Posted April 18, 2008 wel lets start out with the old motor that came out of my car was an h22a4 and the one i just put in my car was an jdm motor h22a. One of my mechanic told me that all I needed to do was take the old distributor and put it on the jdm motor and it would run fine. Now there is no spark from the engine to ignite the gas I dont know wat the problem is can someone tell me wats wrong???? We check the plugs to see if there is any power going to the distributor so now wat do i do can someone help me plzzzz.... Link to comment Share on other sites More sharing options...
HotSauceH22 Posted July 25, 2008 Share Posted July 25, 2008 wel lets start out with the old motor that came out of my car was an h22a4 and the one i just put in my car was an jdm motor h22a. One of my mechanic told me that all I needed to do was take the old distributor and put it on the jdm motor and it would run fine. Now there is no spark from the engine to ignite the gas I dont know wat the problem is can someone tell me wats wrong???? We check the plugs to see if there is any power going to the distributor so now wat do i do can someone help me plzzzz.... I am pretty sure the jdm h22a motor uses an obd1 distributor, your h22a4 is obd2 Link to comment Share on other sites More sharing options...
cranny Posted July 26, 2008 Share Posted July 26, 2008 i think the JDM H22's use an external coil , probably what your mechanics line of thinking is. id say the JDM and USDM dizzys are different besides the coil dude. cant see what else it would be since all your parts worked with old engine. Link to comment Share on other sites More sharing options...
