TurboShiro300zx Posted March 29, 2008 Share Posted March 29, 2008 ok well i have a 90 accord 5 speed, and it has a f22b2 in it right now, ok well i have a h22 with a full swap, trans, wiring harness, computer..ok what all would i have to change to get that h22 in my car Link to comment Share on other sites More sharing options...
Joe W Posted March 29, 2008 Share Posted March 29, 2008 I believe you have everything you need, though I would recommend replacing your mount inserts and do a complete tune up. ie plugs, wires, dizzy cap and rotor, timing belt, water pump, accessory belts, hoses and any thing else that could easily be replaced Link to comment Share on other sites More sharing options...
TurboShiro300zx Posted March 29, 2008 Author Share Posted March 29, 2008 yea i was planning on it, i need to go ahead and get the h22 axels to? so the mounts will hook straight up Link to comment Share on other sites More sharing options...
Joe W Posted March 29, 2008 Share Posted March 29, 2008 Yes mounts will work fine, axles I am not entirely sure just do a google search and you should be able to find that out. Edit: Did a quick search and looks like you'll need the prelude half shaft and the accord axle will work. Link to comment Share on other sites More sharing options...
TurboShiro300zx Posted March 29, 2008 Author Share Posted March 29, 2008 man you've been good help, thanks for goin through the trouble of lookin for me.. Link to comment Share on other sites More sharing options...
Joe W Posted March 29, 2008 Share Posted March 29, 2008 no prob. my brother has a 91 and wants to swap in a h22 and im doin the research so most of it I already know. EDIT: If you get bored I would take the time to look up any info possible that is related to your plans and learn it up as much as possible so when it comes swap time done in no time and its all done properly. Link to comment Share on other sites More sharing options...
TurboShiro300zx Posted March 29, 2008 Author Share Posted March 29, 2008 alright man sounds good, it'll be a little bit before i get that motor in, that f22b2 runs good, but i need more.lol Link to comment Share on other sites More sharing options...
Joe W Posted March 29, 2008 Share Posted March 29, 2008 Yep and it only gets worse. Link to comment Share on other sites More sharing options...
LVh22accord Posted April 25, 2008 Share Posted April 25, 2008 it sounds like you have everything you need. try re-doing the timing on it and a tune up. does the car turn over at all or does it do nothing when you try cranking. as far as axles go the prelude axles will fit but will not work for you. if you put them in the axle will push the wheel bearing out of place. the axle is about an inch to long. your best bet is to use any 90-97 accord ex axles. if u need to know anything else feel free to ask. im pretty good as far as honda's go. i have a 91 h22 accord myself so i know a lot about h22's. Link to comment Share on other sites More sharing options...
