aem fuel regulator
grunt
do i need a gasket for the regulator where it hooks up to the fuel rail its both the aem rail and regulator ?
also whats the stock fuel psi that hondas run at ? the aem is set at 40 is that to much ?
i have a b&m adjustable fule pressure regulator that required you to modify the stock one... as i recall the stock one uses a rubber o ring. is there a groove for one on the aem?
also yea the stock is about 40psi as far as i am aware...
yeah you need an o-ring. as far as pressure goes, you need the specs with vacuum applied and without depends on what the manual says.
