Attaching a meter to the Dashboard
nickysamm
Posted
I am installing a 5" tachometer on my del sol and I would like to have it set on the dash-right in the middle above the a/c vents...any suggestions as to how to drill through the dash safely?!
thanks,
nickysamm
Posted
you can probably take those vents out, so you can see where you're drilling into. measure everything out, and drill a small pilot hole where youre going to be setting in the screws. then just screw it in from there.
and why do you need two tachs?
Posted
I dont really need two tachs but the new one will make my life easier since it has a datalogger in itself and can retreive data later from it :)
