Transmission Overdrive Question
swchan
Posted
Hi, with this winter cold weather is anyone else having problems with their automatic transmission not shifiting into overdrive at highway speeds? I noticed that my 1999 Honda Accord has been doing that ever since it started getting cold. Engine use to run at about 2500rpm @ 70mph but now its at 3000rpm @ 70mph. Is there something wrong with my transmission? :(
Posted
Have your tranny serviced. My mom's Celica did that for a while. It'd take like 20 minutes for the tranny to warm up or something before it'd get into it's overdrive gear. Ended up being a tranny filter or some crap that was clogged.
Posted
whats the fluid level. it sounds like the tranny is slipping too much or it doesn't have enough ATF.
Posted
The same thing happened to my wifes car. The thermostat was failing, hondas temp gauge is sort of like a dummy light with a needle...as long as the engine is within a wide range of temps the gauge will stay centered.
Posted
Fluid level was fine and the transmission was not slipping so I decided to change the thermostat and now it shifts fine. Thanks for the advice.
Posted
i know your problem is fixed , anyone with auto cars , change your fluid , and throw a litre of lucas auto trans additive in. you wont be dissapointed. and honda auto trannys to my knoledge , dont have filters.
