nox Posted December 25, 2007 Share Posted December 25, 2007 does anyone know if there are any companies that make a bellhousing conversion to be able to use the rsx 6 speed with an H motor??? Quote Link to comment Share on other sites More sharing options...
Ben. Posted December 25, 2007 Share Posted December 25, 2007 Don't think an H2K adapter has been made yet. Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 25, 2007 Share Posted December 25, 2007 Don't think an H2K adapter has been made yet. also the engine spins the opposite way than the k series. won't be able to do unless you spin the engine clockwise. Quote Link to comment Share on other sites More sharing options...
kissmeimjwsh Posted January 8, 2008 Share Posted January 8, 2008 i know they make a b series trani adapter im looking into it for my del sol h22a its called h2b kit Quote Link to comment Share on other sites More sharing options...
Ben. Posted January 8, 2008 Share Posted January 8, 2008 They make many adaptors. H2B. H2D. F2D.. I think F2B too. Could be mistaken. Quote Link to comment Share on other sites More sharing options...
Kegger Posted January 8, 2008 Share Posted January 8, 2008 They make a B series tranny for RWD applications. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted January 8, 2008 Share Posted January 8, 2008 i read that some where but didn't know how true that was. Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 12, 2008 Share Posted January 12, 2008 They make a B series tranny for RWD applications. really? Someone have a link to this, or anymore info? Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted January 12, 2008 Share Posted January 12, 2008 really? Someone have a link to this, or anymore info? well i havn,t heard of a b to rwd yet but you can use the crv tranny and go all wheel drive or remove the axles for the front wheels and it will be rear wheel drive. H2K would not be feesible as the engine rotation is counter clockwise while the k tranny works with an engine that spins clockwise. Your would get 6 reverse gears and 1 forward. You can get special cams and spin the engine clockwise to use that tranny but after all the time and money you could just get a whole k Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 13, 2008 Share Posted January 13, 2008 or just turn the engine around backwards.... that would work too. Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 13, 2008 Share Posted January 13, 2008 well i havn,t heard of a b to rwd yet but you can use the crv tranny and go all wheel drive or remove the axles for the front wheels and it will be rear wheel drive. do they have a center lsd that needs to be worked around? Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted January 14, 2008 Share Posted January 14, 2008 do they have a center lsd that needs to be worked around? has a diff for the rear where you can put a posi. Even if you turn the engine the opposite way it still spins the wrong way. Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 14, 2008 Share Posted January 14, 2008 (edited) i meant like a center lsd to limit power sent to the front and rear. lol I meant the tranny and everything. turn the whole drivetrain around 180* then it would work. Edited January 14, 2008 by Pyrorocketeer Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted January 15, 2008 Share Posted January 15, 2008 i meant like a center lsd to limit power sent to the front and rear. lol I meant the tranny and everything. turn the whole drivetrain around 180* then it would work. even if you turn the whole drivetrain 180 it still would not work. you must change the rotation of the engine for the k tranny to work Quote Link to comment Share on other sites More sharing options...
Midnight civic Posted January 15, 2008 Share Posted January 15, 2008 If you turn the motor 180 degrees wouldn't it just turn the tranny to the other side of teh motor, thus, even if it COULD work, still be FWD? Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2008 Share Posted January 15, 2008 even if you turn the whole drivetrain 180 it still would not work. you must change the rotation of the engine for the k tranny to work ..... it will have 5 reverse and one forward if you just mount the h22 to the k trans. now... flip the whole thing 180* thus giving you 5 forward, and 1 reverse.... granted the tranny may not like that, but it can be done. Quote Link to comment Share on other sites More sharing options...
Midnight civic Posted January 15, 2008 Share Posted January 15, 2008 But wouldn't that still make the tranny positioned for a FWD set up?? Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2008 Share Posted January 15, 2008 yes.... I doubt that you could do it without a lot of cutting to move the engine back . The cv's probably won't be able to work at such a high angle , since the axles would now be in front of the engine, and not behind like it was before. Quote Link to comment Share on other sites More sharing options...
