Miamishatchback02 Posted December 24, 2007 Share Posted December 24, 2007 Ok i swapped a d16y8 head the car started fine but sense it has a d15b7 intake it idles wierd it goes up n down and all vacums and all are conected the same way they were before my question is do i have to use the same d16y8 intake manifold to make it idle right or what other intake manifold works cuz the d15b7 intake manifold has a idle control valve and the d16y8 dosnt have it atleast i havent seen it in any pics i seen so help pls? Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 24, 2007 Share Posted December 24, 2007 Ok i swapped a d16y8 head the car started fine but sense it has a d15b7 intake it idles wierd it goes up n down and all vacums and all are conected the same way they were before my question is do i have to use the same d16y8 intake manifold to make it idle right or what other intake manifold works cuz the d15b7 intake manifold has a idle control valve and the d16y8 dosnt have it atleast i havent seen it in any pics i seen so help pls? you can use the d16z6 manifold. make sure you have some play on the throttle cable. if too tight you can receive the same problems you are having Link to comment Share on other sites More sharing options...
