ussamah Posted December 22, 2007 Share Posted December 22, 2007 Does ABS come stock with all JDM SiR2's??? How do i find out if mine has ABS?? thanks Link to comment Share on other sites More sharing options...
cranny Posted December 22, 2007 Share Posted December 22, 2007 should have an ABS light on the cluster. under the hood there will be a big unit(ABS) with a seperate resevoir for brake fluid and bunch of lines comming out of it. Link to comment Share on other sites More sharing options...
solmeistro Posted December 23, 2007 Share Posted December 23, 2007 easy way to tell is to just look under your car at the axles...if it's got teeth around the axle on the brake rotor side (like a cog) then it's abs. or see if there's two lines going to the back of the break rotor, 1 line is a break line, if there's two, then one will be an abs sensor wire. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 23, 2007 Share Posted December 23, 2007 drive down a dirt road and lock the tires up. if it stuttes then you have ABS if it just locks up and no stutter then you have no ABS Link to comment Share on other sites More sharing options...
