Kyle H. Posted December 21, 2007 Share Posted December 21, 2007 Hello, I'm new to this forum so forgive me if i'm not doing it right. I have a problem with my accords vtec system. It doesn't work, it doesn't have any trouble codes or check engine light. I have replaced the thermostat because it was stuck open causing the car to run in open loop because it never got to operating temperature, I thought that was the problem and it wasn't. I've also ran a wire from the connector on the vtec solenoid inside the care to my test meter, at the rpm which vtec is supposed to start working(4800) it shows 1.08-1.10 volts. The vtec solenoid is functional, the oil pressure sensor tests good, it is full of clean oil, and I am all out of ideas. All tips and suggestions are appreciated. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 21, 2007 Share Posted December 21, 2007 from what i have heard there is a screen in the vtec solenoid (spelling) that helps keep metal out of the solenoid. that could be clogged. how many miles are on the car. Link to comment Share on other sites More sharing options...
Kyle H. Posted December 22, 2007 Author Share Posted December 22, 2007 Well I thought about that and i'm sure it needs to be cleaned/replaced, but before I started tearing it apart I wanted to figure out why the solenoid isn't getting voltage. Even if the screen is clogged the PCM should still open the solenoid right? The car has 226,000+, but it has been cared for, so it's not junk. Link to comment Share on other sites More sharing options...
cranny Posted December 22, 2007 Share Posted December 22, 2007 you absolutely should be getting an engine light if vtec is not functioning properly for any reason. if you know someone with an OBD reader , fire it on and see what it says. tap a test light into the wire for the engine light at the ecu for craps and giggles. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 22, 2007 Share Posted December 22, 2007 you absolutely should be getting an engine light if vtec is not functioning properly for any reason. if you know someone with an OBD reader , fire it on and see what it says. tap a test light into the wire for the engine light at the ecu for craps and giggles. yeah use a test light and see if it lights up when vtec comes on. Also can use a volt meter to be accurate as far as voltage. If there is 0volts and when it comes it only shows less than 12 volts the you might have a grounding issue (loose or corroded or damage). Let me know what you find Link to comment Share on other sites More sharing options...
Kyle H. Posted December 23, 2007 Author Share Posted December 23, 2007 I've got a snap-on scanner at work, and it shows no problems whatsoever, check engine light is good. It lights up when you turn the key, and also when you leave something unplugged. I did wire my test meter to the solenoid wire directly on the connector, and the most I have ever got is 1.08-1.10 volts. I'm starting to think it's a ECU problem, it just doesn't seem to turn it on. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 23, 2007 Share Posted December 23, 2007 I've got a snap-on scanner at work, and it shows no problems whatsoever, check engine light is good. It lights up when you turn the key, and also when you leave something unplugged. I did wire my test meter to the solenoid wire directly on the connector, and the most I have ever got is 1.08-1.10 volts. I'm starting to think it's a ECU problem, it just doesn't seem to turn it on. well swap a good ecu in to it and see if you get the same voltage from the output, if you do it is something else. Grounds! Link to comment Share on other sites More sharing options...
Kyle H. Posted December 23, 2007 Author Share Posted December 23, 2007 Will do, I'm going to disassemble the solenoid/spool valve tommorow and clean the little filter. So I will let you know if it solves the problem. Link to comment Share on other sites More sharing options...
