Dalew40 Posted December 17, 2007 Share Posted December 17, 2007 I replaced a burned out brake light. The light works when you press the petal but now there is a beep like when you leave the lights on when you turn off the ignition. Also, all the lights on the entire car come on with the exception of the headlights. That includes the dash lights and parking lights (Front and rear). If they are on with the headlights, they dim when I press the brake petal. Any ideas? Link to comment Share on other sites More sharing options...
Hatch92 Posted December 17, 2007 Share Posted December 17, 2007 the beep is normal when you leave the lights on and remove the key it keeps you from leaving them on. you have a power issue. is the battery gauge on your intrument cluster staying where it normally is? does the car die down when the brake lights come on? Link to comment Share on other sites More sharing options...
MP-03RSXR Posted December 18, 2007 Share Posted December 18, 2007 the beep is normal when you leave the lights on and remove the key it keeps you from leaving them on. you have a power issue. is the battery gauge on your intrument cluster staying where it normally is? does the car die down when the brake lights come on? I agree with Hatch, check the basics. Just out of curiousity- do you have anything else drawing off your battery and/or alternator? (gauges/amp/etc.) And, do the lights dim when the car is running, or when the car is off (but all the lights on)? Link to comment Share on other sites More sharing options...
DC2MONSTAH Posted January 14, 2008 Share Posted January 14, 2008 I agree with Hatch, check the basics. Just out of curiousity- do you have anything else drawing off your battery and/or alternator? (gauges/amp/etc.) And, do the lights dim when the car is running, or when the car is off (but all the lights on)? u got slaps? mabye exposed wiring?? Link to comment Share on other sites More sharing options...
