Cone Assissian Posted December 7, 2007 Share Posted December 7, 2007 I'm having trouble figuring out which harness goes to the EACV. Could somebody tell me what colour the wires are leading to that sensor?? I have three different connectors that could work. I'm throwing a code 14 (eacv), a 16 (fuel injection), and a 20 ( Electric Load Detector) any thought's on that one Link to comment Share on other sites More sharing options...
cranny Posted December 7, 2007 Share Posted December 7, 2007 an ELD code usually indicates a short in one of your sensors wiring , or ecu wiring period for that matter. your electronic load detector is detecting more load in a circuit than should be there. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 10, 2007 Share Posted December 10, 2007 I'm assuming you did the dx to si conversion as I didn't see it written on the posting. The EACV wire colors are blue wire and a black wire. As far as the code 16 fuel injector, it can be a couple of things, I would need to know if you converted from the dual point injection to muiltipoint. If you did it could be a wiring issue. Verify the connections you made with a manual. Remember fix one problem at a time. Fix the code 14 then reset computer. Drive and see what other codes come up. Hope that helps. any more questions hit me up Link to comment Share on other sites More sharing options...
