Prangy Posted November 30, 2007 Share Posted November 30, 2007 Well I guess my valve cover was not the only thing that had stripped bolts. One of the bolts on the oil pan is stripped and it is right by the return line so it leaks like crazy. Now the thread in there is 6*1.00. Can I just do the same thing and drill some out and put a 8*1.25 bolt in there? I just look at that as the easiest way. Do you guys know if they make like a tap extension because the tap isnt going to be able to reach with the oil pan there? Thanks guys Link to comment Share on other sites More sharing options...
EFHatchTuner Posted January 19, 2008 Share Posted January 19, 2008 You can just drill it out and they make things you screw in that are basicaly new threads. I use them all the time when rebuilding trannys. Link to comment Share on other sites More sharing options...
Hatch92 Posted January 19, 2008 Share Posted January 19, 2008 wow another old post. Link to comment Share on other sites More sharing options...
Prangy Posted January 19, 2008 Author Share Posted January 19, 2008 yaaaa old posttttttttttt yaaaa its alive againnnnnnnn yaaaaaaaa already fix that son of a beep Link to comment Share on other sites More sharing options...
cranny Posted January 20, 2008 Share Posted January 20, 2008 You can just drill it out and they make things you screw in that are basicaly new threads. I use them all the time when rebuilding trannys. its called a helicoil , lol. just to clear that up. the less items you describe as "things" the better. Link to comment Share on other sites More sharing options...
Hatch92 Posted January 20, 2008 Share Posted January 20, 2008 cranny is the heat! thats why we love him. Link to comment Share on other sites More sharing options...
