atl2000si Posted November 28, 2007 Share Posted November 28, 2007 how's it going peoples, i recently put a mild t25 turbo setup on my 2000 civic si and my friend gave me some injectors off a turbo supra which i believe are 540's... not totally positive. but i do know i need a resistor box as the are not the right impedence. if you what i might need to do this easily i'd appreciate it. i'm also about to get a safc system on friday so keep that in mind. thanks Link to comment Share on other sites More sharing options...
MP-03RSXR Posted November 29, 2007 Share Posted November 29, 2007 I have no idea if Supra injectors fit on a B16 engine- personally, I'd really be willing to say I'm almost sure they don't. If you need more fuel, here's a couple quick/easy upgrades you can do (you don't need Supra injectors for a mild-turbo setup). 1. Go pull 4 injectors of a B18 (Integra) engine at a junkyard. Or, buy a used set of 4 off Ebay for pretty cheap. 2. Buy a Blox or whatever company you prefer 12:1 FMU. As long as you don't go over 7 or 8 PSI, this is the cheap-man's version of fuel management. Anything above that, I suggest bigger injectors and an actual fuel management system. Link to comment Share on other sites More sharing options...
cranny Posted November 29, 2007 Share Posted November 29, 2007 what does B18 injectors do for him over B16? since they are exactly the same. if he wants to cheap out , get a resistor box out of any OBD0 integra , civic or crx. get yourself some DSM injectors(450) and wire the resistor box in. Link to comment Share on other sites More sharing options...
atl2000si Posted November 30, 2007 Author Share Posted November 30, 2007 thanks guys i appretiate it. i was about to wire in the injectors using the clips off of a 4runner which actually work, but then i suppose i might as well go with the dsm's. any clue as to what i should do with the spark plugs? leave the stock or switch them up. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 30, 2007 Share Posted November 30, 2007 use the stock ones Link to comment Share on other sites More sharing options...
