Cone Assissian Posted November 26, 2007 Share Posted November 26, 2007 so I've change my engine and I can't seem to get any fuel pressure and I don't hear the fuel pump turn on as you turn the car on. What could have missed in the rewiring of the car that would cause the pump not to have power? Link to comment Share on other sites More sharing options...
cranny Posted November 27, 2007 Share Posted November 27, 2007 grounds. mainly the one on the thermostat housing. fuses. main relay. check them in that order. Link to comment Share on other sites More sharing options...
Cone Assissian Posted November 27, 2007 Author Share Posted November 27, 2007 grounds. mainly the one on the thermostat housing. fuses. main relay. check them in that order. I've got the thermostate ground connected and my fuses look ok. Where do I find the main relay, will that be located in the fuse panel in the engine bay? Link to comment Share on other sites More sharing options...
cranny Posted November 27, 2007 Share Posted November 27, 2007 no under the dash. drivers side kick panel i beleve. Link to comment Share on other sites More sharing options...
Cone Assissian Posted November 28, 2007 Author Share Posted November 28, 2007 no under the dash. drivers side kick panel i beleve. yep got it, I took it to work and tested it and of course was faulty, good thing I work at a part store regular price in Can $100 I'll get it for $60 if I go brand new. Maybe I should just toggle switch the fuel pump, just like they do it the real race cars =) Link to comment Share on other sites More sharing options...
