lazz1984 Posted October 31, 2007 Share Posted October 31, 2007 I have a CRX with a b18a turbo and am about to put the motor into my 92 hatch and have a few questions. 1) Will the axles match up? If not what is needed? 2) How do I check if the B18A is OBD1 or OBD0? 3) What if anything else is needed? Thanks for any input. Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2007 Share Posted October 31, 2007 -your gonna need mounts. -axles , im not sure what you have , but im assuming no cause i think the wheel end is different but i could be wrong. youl need integra axles , any 94-01 integra axles. -check right against the firewall on drivers side , where the engine harness plugs into the dash tail , see if theres a resister box there. if your injectors are running through a resistor box , its OBD0 setup. Link to comment Share on other sites More sharing options...
lazz1984 Posted November 1, 2007 Author Share Posted November 1, 2007 ok so since it is OBD1 do I have to make any mods to the harness? Link to comment Share on other sites More sharing options...
cranny Posted November 1, 2007 Share Posted November 1, 2007 no. Link to comment Share on other sites More sharing options...
lazz1984 Posted November 1, 2007 Author Share Posted November 1, 2007 do i need to get a hydro tranny or can i stick with the cable tranny using a mount kit from hasport? Link to comment Share on other sites More sharing options...
cranny Posted November 1, 2007 Share Posted November 1, 2007 you need a hydro tranny. Link to comment Share on other sites More sharing options...
lazz1984 Posted November 1, 2007 Author Share Posted November 1, 2007 Appreciate the info. Link to comment Share on other sites More sharing options...
cranny Posted November 1, 2007 Share Posted November 1, 2007 anymore questions post them up. Link to comment Share on other sites More sharing options...
