1994 TEG Posted October 17, 2007 Share Posted October 17, 2007 ok i have 2 questions one is will the DSM blue top injectors just plug in to my harness or do i have to do mods to the harness. I see alot of guys running them since they are bigger. second is where would i hook up my Autometer water temp gauge to on the head? Do i just take out the factory one and use it there or is there another place? Thanks :help: Link to comment Share on other sites More sharing options...
cranny Posted October 17, 2007 Share Posted October 17, 2007 get yourself an inline tap to put the sensor in. something you can install your sensor in , and put inline in your heater core hose. cut your heater core hose(the one without hot/cold control from inside the car , put your piece inline(in between your cut if you follow me , than run your wires. you cant remove any stock sensors. Link to comment Share on other sites More sharing options...
1994 TEG Posted October 17, 2007 Author Share Posted October 17, 2007 Thanks, i get what you mean. And where can i get an inline tap at? Link to comment Share on other sites More sharing options...
