moody95 Posted September 21, 2007 Share Posted September 21, 2007 I have a b16 in a 95 civic and it is overheating when it gets hot out. I am using the radiator from the d series. Should this radiator work or is that the problem. Link to comment Share on other sites More sharing options...
Kegger Posted September 21, 2007 Share Posted September 21, 2007 Should work fine, check your thermostat, then your water pump... But very first check your fluid levels Link to comment Share on other sites More sharing options...
moody95 Posted September 22, 2007 Author Share Posted September 22, 2007 Should work fine, check your thermostat, then your water pump... But very first check your fluid levels My fluid levels are fine. When It gets that hot shouldn'y the fan be runing all the time? It dosn't come on. Link to comment Share on other sites More sharing options...
Kegger Posted September 22, 2007 Share Posted September 22, 2007 Yeah it should. Check the fuses, then the connections. If everything is good your fan may be bad. Link to comment Share on other sites More sharing options...
crxtacy Posted September 23, 2007 Share Posted September 23, 2007 had one of the same problem.turned out the coolant fan switch was bad. Link to comment Share on other sites More sharing options...
