collegetuner Posted September 10, 2007 Share Posted September 10, 2007 So I have an 89 Honda Civic Hatch, and it has a b16 in it with a t3/t4 turbo on it. I recently just started having a problem with white smoke coming out of my exhaust. The weird thing is it gets worse the more I drive, when I first start the car it barely smokes, but after say 15-20 minutes of operation it steadily gets worse, to the point where I can't even see the person behind me. I don't even have to get up in high RPM's for the problem to occur. A little information that may help, my clutch is about to go out and I am replacing it tommorow, I don't see why that would even matter. I figured I'd ask if you guys thought it would be a cracked head gasket, or if it is the head itself? The new engine only has about 70,000 miles on it, and the oil doesn't really look contaminated, and the coolant level in the car hasn't dropped significantly. Any opinions on what this could be? Link to comment Share on other sites More sharing options...
lysol Posted September 10, 2007 Share Posted September 10, 2007 Might want to check if your getting oil into your intake from your turbo. Thats the first thing i would check Link to comment Share on other sites More sharing options...
Kastigir Posted September 10, 2007 Share Posted September 10, 2007 White smoke is coolant. Warped/cracked head or bad head gasket. Link to comment Share on other sites More sharing options...
95exd16z6 Posted September 10, 2007 Share Posted September 10, 2007 go to pepboys or wherever and get a compression tester. theyre like 20 bucks nd thatll let you know wether its your head or not. i did a compression test when i blew my first motor. REALLY easy Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted September 11, 2007 Share Posted September 11, 2007 easiest way to see if its a head gasket, or warped head, is to open the radiator cap. if its low, bubbling, or gurgling when the engine is running, then you can pretty much bet on one of the two is f-ed up. Link to comment Share on other sites More sharing options...
cranny Posted September 11, 2007 Share Posted September 11, 2007 id say its a head gasket for sure , does it run sputtery? Link to comment Share on other sites More sharing options...
