TurboShiro300zx Posted September 9, 2007 Share Posted September 9, 2007 ok well ever since i got the car there has been a bad grinding noise..and when i say bad, i mean bad..when i got it i thought it was a bad throw out barring..so i went and had a brand new clutch, pressure plate, and throw out barring, and the guy said that he had to go have the flywheel shaved, because the person who put the clutch in previously put the flywheel in to far down or something like that..but anyhow the sound it only does it when you release the clutch, if you are sitting still and release, then it sounds like a grind like a throw out barring going bad, but if you are going in first and second exspecially it will make a like knock and grind..i need some help Link to comment Share on other sites More sharing options...
