linuxman Posted August 25, 2007 Share Posted August 25, 2007 Ok....... wtf. My car drove/started fine yesterday, I hop in it just a few minutes ago to get some lunch, and it wont crank. Turns over just fine, radio/lights/electronics all work fine, but wont start. I've noticed a few issues with a main relay for the car, is there a known issue that keeps the car from starting but allows it to turn over? or a fuse for the fuel pump somewhere? i checked the fuse box under the hood and the one in the car and I cant find a fuse for the pumps anywhere.... help! Link to comment Share on other sites More sharing options...
Hatch92 Posted August 25, 2007 Share Posted August 25, 2007 if you put the ignition to on, not start on, does the fuel pump kick on. if not then either the fuse is blown or the fuel pump is bad. if it kicks on then you are having an ignition issue, check the wires, cap, and rotor make sure everything is tight. the rotor in my 92 came undone a while back and that caused the car from starting. if none of this fixes it then i'm at a loss. Link to comment Share on other sites More sharing options...
Kastigir Posted August 26, 2007 Share Posted August 26, 2007 More than likely it's your relay. New part from the dealer is around 75 bucks. Link to comment Share on other sites More sharing options...
linuxman Posted August 28, 2007 Author Share Posted August 28, 2007 apparently it is the relay... after it cooled off a little (from our usual afternoon 100+ degrees with 90% humidity...) it started just fine. I've heard you can re-solder the connections on the relay to fix it, I might try that for grins to see if it helps any. Link to comment Share on other sites More sharing options...
GUESSMAN Posted September 6, 2007 Share Posted September 6, 2007 make sure all of your grounds are tight to. Link to comment Share on other sites More sharing options...
