dbtower Posted July 28, 2007 Share Posted July 28, 2007 got done a couple days ago slapping the b16 into the eg, now i have some questions???? does anyone have a diagram for the p30 pinnout so i can wire the knock sensor??also need to figure out which wires need to be wired up and what not for the 7 to 4 wire conversion for the o2 sensor...if anyone has answers or can help please let me know.....note:used the vx harness for wiring since it was a jdm harness that was sent with the engine Link to comment Share on other sites More sharing options...
lysol Posted July 28, 2007 Share Posted July 28, 2007 ECU PIN OUT P30 OBD 1 ECU PIN OUT P30 OBD 1 PIN COLOR CIRCUIT A1 BRN INJ1 INJ1 A2 YEL INJ4 INJ4 A3 RED INJ2 INJ2 A4 ORN/WHT VTS VTEC solenoid A5 LT BLU INJ3 INJ3 A6 ORN/BLK PO2SHTC O2 sensor (heating element) A7 GRN/YEL FLR1 fuel pump A8 (empty) A9 GRN/WHT IACV IAC valve A10 (empty) A11 (empty) A12 YEL/GRN FANC Fan Output A13 GRN/ORN MIL MIL (check engine light) A14 (empty) A15 BLK/RED ACC (a/c compressor clutch) A16 WHT/YEL ALT C alternator A17 A18 (empty) A19 (a/t trans only) A20 RED PCS EVAP purge control solenoid A21 RED/GRN ICM ICM A22 (empty) A23 BLK PG1 ground A24 BLK PG2 ground A25 YEL/BLK IGP2 to main relay and to ground A26 BRN/BLK LG1 ground B1 YEL/BLK IGP2 to pin A25 B2 BRN/BLK LG2 ground to shields for CYP & TDC B3 (a/t trans only) B4 (a/t trans only) B5 BLU/RED ACS a/c switch B6 (empty) B7 (a/t trans only) B8 BRN/RED PSPSW PSP switch B9 BLU/WHT clutch interlock switch B10 YEL/BLU VSS vehicle speed sensor B11 ORN CYP P CYP -P B12 WHT CYP M CYP -M B13 ORN/BLU TDC P TDC -P B14 WHT/BLU TDC M TDC -M B15 BLU/GRN CKP P CKP -P B16 BLU/YEL CKP M CKP -M D1 WHT/BLU VBU Back Up Power D2 GRN/WHT BKSW brake switch D3 KS Knock Sensor D4 BRN SCS service check connector D5 (empty) D6 ORN/BLU VTM VTEC pressure switch D7 LT BLU TXD/RXD (data link connector) D8 (empty) D9 PNK ALT F alternator D10 GRN/RED ELD electric load detector D11 RED/BLU TPS TPS Signal D12 YEL/GRN D13 RED/WHT ECT ECT sensor D14 WHT PHO2S O2 sensor D15 RED/YEL IAT IAT sensor D16 WHT/YEL VREF VREF D17 WHT MAP Map Signal D18 (a/t trans only) D19 YEL/GRN VCC1 MAP 5V D20 YEL/WHT VCC2 TPS 5V D21 GRN/BLU SG1 MAP GND D22 GRN/WHT SG2 TPS GND Link to comment Share on other sites More sharing options...
lysol Posted July 28, 2007 Share Posted July 28, 2007 http://g2ic.com/forums/attachment.php?atta...mp;d=1107796494 Wiring Diagram Helpfull links http://hondaswap.com/swap-articles/obd1-b-...ng-guide-29111/ http://hondaswap.com/swap-articles/1-wire-...nversion-32519/ http://hondaswap.com/swap-articles/vx-5-wi...sor-info-13759/ http://honda-tech.com/zerothread?id=478377 http://honda-tech.com/zerothread?id=151379...mp;d=1107796494 Link to comment Share on other sites More sharing options...
