fifty9singlecab Posted July 27, 2007 Share Posted July 27, 2007 I was wondering if it may be something besides a rod. My 1988 Prelude 5 spd. runs great and has just had a new clutch installed and now this. You can start it and it fires right up and purrs like a kitten. Then when you rev up the motor it knocks. I just changed the oil and put some Lucas treatment in it but it doesn't seem to be helping. Thanks for any help or pointers. Link to comment Share on other sites More sharing options...
crxtacy Posted July 28, 2007 Share Posted July 28, 2007 try using a higher octane gas .(92 octane ) Link to comment Share on other sites More sharing options...
jay2020 Posted August 2, 2007 Share Posted August 2, 2007 i had the same problem on my lude and it turned out it was a rod knock so i got a new motor. on my friends eg he had a knocking sound too but it turned out it was his timing belt. Link to comment Share on other sites More sharing options...
typeSH Posted August 9, 2007 Share Posted August 9, 2007 I was wondering if it may be something besides a rod. My 1988 Prelude 5 spd. runs great and has just had a new clutch installed and now this. You can start it and it fires right up and purrs like a kitten. Then when you rev up the motor it knocks. I just changed the oil and put some Lucas treatment in it but it doesn't seem to be helping. Thanks for any help or pointers. Sounds like a rod knock. Have you tried using fully synthetic oil to try and dampen the noise? Link to comment Share on other sites More sharing options...
Kegger Posted August 9, 2007 Share Posted August 9, 2007 Oh my god... You did not just tell him to hide the noise did you? You have got to be craptin me! Never try to mask a bad sound. Rod knock is not a good thing. Drain your oil, and pull your oil pan and look at your crankshaft, rod bearings, main bearings, rod bolts and rods themselves. If there is anything that doesn't look right its probably not. Link to comment Share on other sites More sharing options...
GUESSMAN Posted September 6, 2007 Share Posted September 6, 2007 sounds like something that just happened to my 02 Altima (yes i know it's not a Prelude but i have a 88 S Lude) a rod knock is not a good thing. i ended up having to replace my whole engine in the Altima. that was not cheap, but if you have to replace your engine, you probably can find another 2.0 pretty cheap. http://www.nippon-motors.com/honda.htm i hope that helps some people don't like to search. Link to comment Share on other sites More sharing options...
