fifty9singlecab Posted July 27, 2007 Share Posted July 27, 2007 I just put a new clutch in my 88 Prelude 286,000 miles and when I was driving it you could hear a slight knocking sound when you accelerated. It seemed as it did it more about half throttle. As it does this the oil light blinks. It is full of oil, and this wasn't like this before the clutch went out. I bought 10w30 Castrol High mileage oil for it and a new filter, Do I need some oil treatment to add to my oil? Thanks for any help.... Link to comment Share on other sites More sharing options...
cranny Posted July 28, 2007 Share Posted July 28, 2007 if the oil light is comming on , its prolly a rod bearing knocking. Link to comment Share on other sites More sharing options...
fifty9singlecab Posted July 28, 2007 Author Share Posted July 28, 2007 Is that a hard fix and is it expensive? Link to comment Share on other sites More sharing options...
Kastigir Posted July 28, 2007 Share Posted July 28, 2007 If it's a rod bearing, it should be knocking all the time. Link to comment Share on other sites More sharing options...
Hatch92 Posted July 28, 2007 Share Posted July 28, 2007 is it a knock or a loud tap? like a hard valve tap. Link to comment Share on other sites More sharing options...
fifty9singlecab Posted July 29, 2007 Author Share Posted July 29, 2007 It's like a clank/knock and it does it fast, as you rev up the motor. Link to comment Share on other sites More sharing options...
cranny Posted July 30, 2007 Share Posted July 30, 2007 its a rod bearing. if you dont run it anymore , might be a cheap a fix as bearings and a rod , but youl most likely need a crank too. unless its not bad. Link to comment Share on other sites More sharing options...
89crxsi1003 Posted August 16, 2007 Share Posted August 16, 2007 sounds like you oil pump went out on you Link to comment Share on other sites More sharing options...
