89crxsi1003 Posted July 27, 2007 Share Posted July 27, 2007 will a tranny from a d16a6 bolt u to a d15b jdm? Are the clutches the same? Link to comment Share on other sites More sharing options...
Kastigir Posted July 27, 2007 Share Posted July 27, 2007 Tranny should, clutch I'm not sure. Link to comment Share on other sites More sharing options...
cranny Posted July 27, 2007 Share Posted July 27, 2007 ones a cable clutch and ones a hydro clutch. yes the A6 tranny will bolt to the D15B. the pressure plate and flywheel are definitely the same , the disc might be different if the mainshaft teeth are different. i cant remeber off hand exactly what trannys have different shafts. the clutch has to match the tranny. Link to comment Share on other sites More sharing options...
lysol Posted July 27, 2007 Share Posted July 27, 2007 Yes, the transmission will bolt up. Just use the clutch from d16a6 to match up teeth on the shaft. Link to comment Share on other sites More sharing options...
