97blackonblackcivic. Posted July 14, 2007 Share Posted July 14, 2007 my dash lights wont work, i checked all the fuses and they are good. could it be my ecu?? Quote Link to comment Share on other sites More sharing options...
Ben. Posted July 14, 2007 Share Posted July 14, 2007 (edited) As in, ALL of them or just the cluster? Bulbs in the cluster could've gone bad if it's just those. Edited July 14, 2007 by busted ls1 Quote Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted July 15, 2007 Author Share Posted July 15, 2007 As in, ALL of them or just the cluster? Bulbs in the cluster could've gone bad if it's just those. yeah its just the ones on the cluster. Quote Link to comment Share on other sites More sharing options...
Ben. Posted July 15, 2007 Share Posted July 15, 2007 Bulbs in the cluster are probably bad. What could've CAUSED it is beyond me. You can either replace said bulbs or get another cluster of your choice. Quote Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted July 21, 2007 Author Share Posted July 21, 2007 Bulbs in the cluster are probably bad. What could've CAUSED it is beyond me. You can either replace said bulbs or get another cluster of your choice. do you know if they are hard to change?? Quote Link to comment Share on other sites More sharing options...
lugrench Posted July 22, 2007 Share Posted July 22, 2007 I've never actually tore one appart but to my knowledge there are multiple bulbs in there and the chances of them all poping at once are VERY slim. i've had older civics where like half of the speedo is dim because of a bad bulb, but i can't imagine the bulbs would cause the whole thing not to work. I would think it's a loose wire behind your cluster or maybe even the dimmer control switch?? i've got 2000 accord that the HVAC contol lights don't work but if i hit the dash in right place they work for a while, which tells me it's just a conection somewhere. Good Luck!! Quote Link to comment Share on other sites More sharing options...
jazz Posted October 17, 2007 Share Posted October 17, 2007 do you know if they are hard to change?? it is easy. once you get the cluster unplugged it is pretty obvs. there are three main bulbs, it is probobly one of them. when you are changing the one, be carefull, in the process of unplugging the cluster another might go out also. Quote Link to comment Share on other sites More sharing options...
