Joe W Posted June 25, 2007 Share Posted June 25, 2007 I cant get my crx running, Im looking for ideas. The car just cranks when trying to start, and i get this annoying beeping noise and the check engine light stays on. So i pulled up the carpet to find that the ecu led doesnt turn on when i turn the key on. In my running crx when i turn the key on it beeps 5 times/and the check engine light cuts off like its supposed to and the led on the ecu blinks once to show that it is turned on. Soo... I checked all fuses under dash and in the engine bay to find all are working, and I even removed the ecu from the NON-running car and put it in mine. When I did this the ecu works perfectly allowing the car to operate correctly. Now I dont know if the harness has a short somewhere how to find out where, or if it is just no good or a completely different problem all together??? PLEASE HELP Quote Link to comment Share on other sites More sharing options...
