ArtyMillz Posted June 18, 2007 Share Posted June 18, 2007 ok whenever i drive and my b16 gets to warm the car shuts off and it will not start untill the engine is completlyyyyy cold again wich is like 7 hoursss.....whats causing this...im thinking a sensor but then again im not a mechanic....i was also thinking maybe a tempature sensor but my heat gauge never goes up when the car shuts...idk its something tricky Link to comment Share on other sites More sharing options...
crxtacy Posted June 18, 2007 Share Posted June 18, 2007 sounds like the ECT sensor is bad. Link to comment Share on other sites More sharing options...
ArtyMillz Posted June 19, 2007 Author Share Posted June 19, 2007 well i found out what it was...it was this wire that was coming off my msd distributor and its loose and when it shakes it shuts the car off....and the radiator fan was messed up but its fixed Link to comment Share on other sites More sharing options...
ArtyMillz Posted June 24, 2007 Author Share Posted June 24, 2007 well i guess it was more then what i siad becasue after i fixed the fan and distributor it shut down when i wasw driving again...so agewrvating i cant take the car newhere without worrying and a few guys looked at it and cant figure it out Link to comment Share on other sites More sharing options...
crxtacy Posted June 26, 2007 Share Posted June 26, 2007 Check your grounds .Make sure there tight and cleaned.If its all good,try running the car and start wiggling the engine harness from inside the engine compartment to the computer area.Maybe you got a loose wire or connector somewhere. Link to comment Share on other sites More sharing options...
cranny Posted June 26, 2007 Share Posted June 26, 2007 if its still doing it , its probably an ignitor. Link to comment Share on other sites More sharing options...
