corn0807 Posted June 10, 2007 Share Posted June 10, 2007 I need some help!! I just changed the head gasket on my 95 honda civic 1.5 liter engine. The intake and exhaust manifold are screwed in fine. All the hoses have connected. The distributor has also been re-installed with the same wires, I changed the spark plugs to NGK. The engine is turning but will not start, the car is also a 5 spd. I made sure that it was at tdc when all the work was done. Why is this happening? Link to comment Share on other sites More sharing options...
crxtacy Posted June 10, 2007 Share Posted June 10, 2007 check for spark ? check if you have fuel ? Link to comment Share on other sites More sharing options...
corn0807 Posted June 10, 2007 Author Share Posted June 10, 2007 check for spark ? check if you have fuel ? there's fuel in the car... how do i check for a spark? Link to comment Share on other sites More sharing options...
Kegger Posted June 10, 2007 Share Posted June 10, 2007 No, dude check to see if you're getting gas thru the injectors. Which means you need to check for fuel pressure. Check for spark by pulling one of the plugs and turning the car over, you should see a spark. Link to comment Share on other sites More sharing options...
cranny Posted June 10, 2007 Share Posted June 10, 2007 fuel is not his problem given the job that was done i say this. im gonna say he has timing issues. all he mentioned was the engine was at TDC , well , thats half the battle. set your timing again dude. or at least have a look and make sure its right. Link to comment Share on other sites More sharing options...
corn0807 Posted June 10, 2007 Author Share Posted June 10, 2007 How do I set the timing? Is this a problem with the distrubutor? I'm gonna check the spark plugs to see if there is a spark. Link to comment Share on other sites More sharing options...
corn0807 Posted June 10, 2007 Author Share Posted June 10, 2007 I almost forgot while the engine is cranking the check engine light goes on Link to comment Share on other sites More sharing options...
cranny Posted June 11, 2007 Share Posted June 11, 2007 hmmm , thats different. something not put together or hooked up right i wanna say. a word of wise for the future , dont remove the intake manny when taking the head off. you dont have to. so your saying you turn the key to on , the engine light comes on for 3 seconds than goes out , than when you crank the engine , it comes on again? and stays on as long as power is on? Link to comment Share on other sites More sharing options...
ge_ej1 Posted June 11, 2007 Share Posted June 11, 2007 hmmm , thats different. something not put together or hooked up right i wanna say. a word of wise for the future , dont remove the intake manny when taking the head off. you dont have to. so your saying you turn the key to on , the engine light comes on for 3 seconds than goes out , than when you crank the engine , it comes on again? and stays on as long as power is on? i would have to say that your timing is off, or if not that the whole distributor is dead Link to comment Share on other sites More sharing options...
