spike10197 Posted June 4, 2007 Share Posted June 4, 2007 should i change it right away? will it affect my honda? how can u tell if its the oxgen sensor? one more thing if it is out then how do you change it? Link to comment Share on other sites More sharing options...
JapaneseDomesticMarketGSR Posted June 4, 2007 Share Posted June 4, 2007 should i change it right away? will it affect my honda? how can u tell if its the oxgen sensor? one more thing if it is out then how do you change it? WTF is the problem genius? Link to comment Share on other sites More sharing options...
spike10197 Posted June 4, 2007 Author Share Posted June 4, 2007 idk if its a problem but the ecu or the computer w/e the hell it is. it keeps blinking one time and i looked it up on the internet and its saying that it has to do something with the oxygen sensor. Link to comment Share on other sites More sharing options...
crxtacy Posted June 4, 2007 Share Posted June 4, 2007 It could be anything that will throw you an o2 sensor code . running too rich.Or runing too lean. ecu not getting a signal ? Need more details on the symptoms ? how is it running ? more input the better ! Link to comment Share on other sites More sharing options...
spike10197 Posted June 5, 2007 Author Share Posted June 5, 2007 It could be anything that will throw you an o2 sensor code . running too rich.Or runing too lean.ecu not getting a signal ? Need more details on the symptoms ? how is it running ? more input the better ! i dont know if its running to rich or too lean. i just know that the ecu is blinking once. so i just went by what the guide told me Link to comment Share on other sites More sharing options...
