jjcuff1 Posted May 30, 2007 Share Posted May 30, 2007 several places online and locally have teg rear disc conversion. I figure get a setup, clean the trailing arms and press in new bushings, paint calibers, new brake lines, new pads, new bolts if needed and swap in (maybe swaybar and beaks kit too) that is for 9.4" rears what about front? can I get bigger rotors without changing much from another hinda or acura? my brakes are WAY faded and require pumping at stops. It is either a bad bleed air problem with bleed valves or cables are shot. I am going to bleed tommorrow to see if they improve but I want better stopping power. maybe just larger fronts would do instead of a conversion Link to comment Share on other sites More sharing options...
