DResmini Posted May 28, 2007 Share Posted May 28, 2007 I have an issue... So lately I've been noticing that whenever I turn too tightly, the brake light on the dash comes on, and then goes off. Well now, after even gentle turns, it comes on and stays on. Moving on, now the ABS light comes on periodically as well. I just had the main brake cylinder and fluids replaced/refilled on my last oil change.. is this a sensor going out or something I should be worried about? Link to comment Share on other sites More sharing options...
crxtacy Posted May 28, 2007 Share Posted May 28, 2007 check your brake reservoir and the cap.If the brake fluid is full then its prolly the cap.Cap is what turn on the brake light on the dash indicating the fluid is low.When that light comes ON, the abs light comes ON as well.Clean the cap or replace it.Thats where the sensor is located . Link to comment Share on other sites More sharing options...
