Overheat-Highway only
jjcuff1
tried new cap, purged system, (no flush or thermostat yet)
But city driving AC on or off no problem. stays at 50% or less
as soon as I get to 70-80mph straight highway driving it gets pegged.
I turn the heat on full blast and it drops to 70% but still creeps up at highway speeds
as soon as I get off the highway it drops to 50% again
AC or heat on/off do not matter over the long drives it is heat related?
I suspect the water pump? at city driving it is seeing rpm changes and therfore moving, maybe at steady rpm it is stalling? I hear no squealing from it though.
I am going to backflush and replace thermo.
oh after I stopped while still hot with AC on both fans are working.
i have a 94 s
thermo sticking shut sounds like off hand. its also very possible your rad is rotten , have a look at the fins , see if they just crumble away.
