EZNACHO Posted May 20, 2007 Share Posted May 20, 2007 I just got the LS MESHES I payed 100 for them without tires... I wanted to know what tires would be a good size for my car "THE ONE ON THE SIG" (DA) The car has stock suspension and stock height. Just wanted to know what SIZE TIRES I SHOULD GET please post your opinions! Thank YOu. Link to comment Share on other sites More sharing options...
Ben. Posted May 20, 2007 Share Posted May 20, 2007 Why not ask a tire shop what they recommend? That's a pretty vague question. We don't know whether or not you're going to lower your car(sidewall height comes into play there) or what. Link to comment Share on other sites More sharing options...
EZNACHO Posted May 20, 2007 Author Share Posted May 20, 2007 Why not ask a tire shop what they recommend? That's a pretty vague question. We don't know whether or not you're going to lower your car(sidewall height comes into play there) or what. VAGUE??? I'm describing to you how my car is SET UP AT THE MOMENT for a reason! Link to comment Share on other sites More sharing options...
Ben. Posted May 20, 2007 Share Posted May 20, 2007 It's VAGUE, you clown because EVEN THOUGH IT'S AT STOCK RIDE HEIGHT AND STOCK SUSPENSION NOW, THE TIRES YOU BUY FOR IT THEN MAY NOT FIT AFTER LOWERING. Permitted you do so. Ass. Link to comment Share on other sites More sharing options...
EZNACHO Posted May 21, 2007 Author Share Posted May 21, 2007 It's VAGUE, you clown because EVEN THOUGH IT'S AT STOCK RIDE HEIGHT AND STOCK SUSPENSION NOW, THE TIRES YOU BUY FOR IT THEN MAY NOT FIT AFTER LOWERING. Permitted you do so. Ass. Please tell me who the heck said anything about lowering it? WHO WHO? Exactly now if you don't have opinions about what tire size/measurements to use STFU and go call someone else an ass. Link to comment Share on other sites More sharing options...
Ben. Posted May 21, 2007 Share Posted May 21, 2007 I'll pass, you illiterate little child. I suppose you're just going to leave out the part where I said -- "permitted you do it"? Link to comment Share on other sites More sharing options...
zimmy709 Posted May 21, 2007 Share Posted May 21, 2007 oh for gods sake... here we go again. anyways... im assuming you will be keeping the sidewall the same because that just makes sense... maybe not, but im assuming. now you really don't have too many options on that wheel. you could go as small as a 185 probably, but what is the point in that. as for wider, you will be able to go up to a 215 even lowered you will be ok (lowered reasonably) mainly because of the offset of that wheel. the only way you will REALLY be running into problems is if you put on some silly thick wheel spacers that would take you out beyond +40 on your offset. but those wheels being stock gsr wheels were made fairly conservative at a 6 inch width, and you should be able to run anything between 185 and 205, i would recommend a 205 as they ran a 195 from the factory(195-55-15). 215 is just too damn wide for the width of the wheel and you would be squeezing it and messing with the tire's contact patch by doing so. the only reason i know all of this is because i an gettin 15's for my sol, but i will be able to go a bit wider due to the fact that im getting wider than stock 15's 6.5-7 inch width probably rota c8's. but once again, good choice on those oem gsr's i really like them! any ideas on what tire you will be getting? Brand and model? just curious Link to comment Share on other sites More sharing options...
Hatch92 Posted May 21, 2007 Share Posted May 21, 2007 205/35/16, that is if they are 16's. 195/55/15, for 15's Link to comment Share on other sites More sharing options...
mycarsux Posted May 21, 2007 Share Posted May 21, 2007 good choice on those oem gsr's i really like them! typo?? he's got LS meshes, not GSR's Link to comment Share on other sites More sharing options...
zimmy709 Posted May 22, 2007 Share Posted May 22, 2007 typo?? he's got LS meshes, not GSR's oh i always thought those were off the gsr... my mistake in any case i love them. Link to comment Share on other sites More sharing options...
mycarsux Posted May 22, 2007 Share Posted May 22, 2007 lol, why do you think they call them "LS" meshes. Link to comment Share on other sites More sharing options...
RSX-S-T Posted May 22, 2007 Share Posted May 22, 2007 Should this thread be in wheels and tires? Link to comment Share on other sites More sharing options...
EZNACHO Posted May 23, 2007 Author Share Posted May 23, 2007 oh for gods sake... here we go again. anyways... im assuming you will be keeping the sidewall the same because that just makes sense... maybe not, but im assuming. now you really don't have too many options on that wheel. you could go as small as a 185 probably, but what is the point in that. as for wider, you will be able to go up to a 215 even lowered you will be ok (lowered reasonably) mainly because of the offset of that wheel. the only way you will REALLY be running into problems is if you put on some silly thick wheel spacers that would take you out beyond +40 on your offset. but those wheels being stock gsr wheels were made fairly conservative at a 6 inch width, and you should be able to run anything between 185 and 205, i would recommend a 205 as they ran a 195 from the factory(195-55-15). 215 is just too damn wide for the width of the wheel and you would be squeezing it and messing with the tire's contact patch by doing so. the only reason i know all of this is because i an gettin 15's for my sol, but i will be able to go a bit wider due to the fact that im getting wider than stock 15's 6.5-7 inch width probably rota c8's. but once again, good choice on those oem gsr's i really like them! any ideas on what tire you will be getting? Brand and model? just curious Yeah I am going to get KHUMO TIRES Thanks for the INPUT Link to comment Share on other sites More sharing options...
Humphries Posted May 24, 2007 Share Posted May 24, 2007 that zimmy guy has a sexy sol. Link to comment Share on other sites More sharing options...
jasoninarmy Posted July 4, 2007 Share Posted July 4, 2007 go with a 205/50zr15. they should be wide enough to stick to the road and not too much height for them to roll. trust me i work at a tire store:thumbup: Link to comment Share on other sites More sharing options...
Humphries Posted July 4, 2007 Share Posted July 4, 2007 what are zr tires? Z rated R compounds? thats not how the number is set up. Link to comment Share on other sites More sharing options...
Ben. Posted July 5, 2007 Share Posted July 5, 2007 Yea, actually Billy on some tires it is. I had Nitto's on the Bullitt's I had on my old Mustang that were 315/45/ZR18. Link to comment Share on other sites More sharing options...
Humphries Posted July 5, 2007 Share Posted July 5, 2007 tou'che! Link to comment Share on other sites More sharing options...
cranny Posted July 5, 2007 Share Posted July 5, 2007 he wants 205/45/17 , im pretty sure you can fit 215/45/17 on there as well , which would be better. Link to comment Share on other sites More sharing options...
Humphries Posted July 5, 2007 Share Posted July 5, 2007 17'' tires for 15'' OEM acura wheels? Link to comment Share on other sites More sharing options...
