DanJDT1 Posted April 18, 2007 Share Posted April 18, 2007 88 Civic 91 Tank And Pump Pump was shot. So I just pulled the entire tank out. and use the 91 civic i bought from a friend for $100 (totaled it in a wreck) And Put the 91 pump. and tank in the 88 Civic. The 88 Only has 2 Wires. Ground and Live ( i am assuming here) The 91 Pump has 3. So I kept those intack, Cut the 88 2 Wireharness, and spliced the end of the 91 onto it. It worked for awhile. Now I keep popping relays. Cause? Solution? Link to comment Share on other sites More sharing options...
Kegger Posted April 19, 2007 Share Posted April 19, 2007 You are grounding a hot wire, either insulate all connections or just buy the correct pump. Link to comment Share on other sites More sharing options...
