TrailMystic Posted April 16, 2007 Share Posted April 16, 2007 I bought a great looking '94 VTEC sol a few weeks ago. It runs great, and looks like it's only 2 years old (only 52K). But, I took a calculated risk in buying it because it has a Salvage/Rebuild title, which means it was totaled in an accident, flooded, or stolen. I have no regrets. I am happy with the car, but I am trying to solve the mystery of why it has a salvage title. The previous owner did not know either. He had a good mechanical background, and he said he checked the car out carefully and he couldn't see any evidence of repairs from a wreck or water damage (electronics all work well). I couldn't see any evidence either of a wreck or water damge. The previous owner guessed it had been stolen, which probably means it was stripped - maybe just the coveted VTEC motor was taken and replaced later after it was declared a loss. So, where is the engine serial number? Does the engine usually have the same serial number as the VIN of the car, or does it have a different number. The present engine runs great - really tight and quiet, but I am just trying to put together the pieces of this puzzle. Pete Link to comment Share on other sites More sharing options...
TS John Posted April 16, 2007 Share Posted April 16, 2007 First of all, if it's the coveted VTEC engine in there then it'll have dual overhead cams. That's one indicator. But you can read the engine code off a little square down and to the left side of the front of the block, just below the head. It should say B16A3 I think. Link to comment Share on other sites More sharing options...
TrailMystic Posted April 16, 2007 Author Share Posted April 16, 2007 So, what's a HPI check? Is that the UK equivalent to our CarFax? If so, the CarFax does not give details about why it was a salvage title. I had a CarFax before I bought it. Yes, the present engine is the B16A3 DOHC. If it was replaced, someone replaced it with the right engine. Also, it's not an option to go back to the insurance company - I have no owner names or claim numbers to do that. Pete Link to comment Share on other sites More sharing options...
Ben. Posted April 16, 2007 Share Posted April 16, 2007 So, what's a HPI check? Is that the UK equivalent to our CarFax? If so, the CarFax does not give details about why it was a salvage title. I had a CarFax before I bought it. Yes, the present engine is the B16A3 DOHC. If it was replaced, someone replaced it with the right engine. Also, it's not an option to go back to the insurance company - I have no owner names or claim numbers to do that. Pete Um, if carfax doesn't tell you if the vehicle has been in any wrecks/totaled, they're screwing you out of money. Link to comment Share on other sites More sharing options...
TrailMystic Posted April 16, 2007 Author Share Posted April 16, 2007 All carfax says is there is an alert because a Salvage/Rebuild title was issued. It does not specify the reason for the rebuild. Back to the original question, how can you tell if the engine is original. If it was wrecked, that's OK with me because it looks and runs great. I'm just curious if it was stripped. Pete Link to comment Share on other sites More sharing options...
airjordan223 Posted April 16, 2007 Share Posted April 16, 2007 First of all, if it's the coveted VTEC engine in there then it'll have dual overhead cams. That's one indicator. But you can read the engine code off a little square down and to the left side of the front of the block, just below the head. It should say B16A3 I think. check that first Link to comment Share on other sites More sharing options...
TrailMystic Posted April 17, 2007 Author Share Posted April 17, 2007 check that first Yes, it's a DOHC VTEC motor in there now - B16A3. Runs great. Pete Link to comment Share on other sites More sharing options...
TS John Posted April 17, 2007 Share Posted April 17, 2007 That's weird that you weren't told why it has that title from the CarFax. Hm. Did the guy who sold it to you take off any of the body pieces. That might reveal evidence of a repaired wreck, but if it looks fine and runs fine I might just leave it. Just don't sell it since you won't get any money. And sols are perfect anyway for the money. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 17, 2007 Share Posted April 17, 2007 you could check around the car comparing the VIN numbers to see if they all match up Link to comment Share on other sites More sharing options...
Ben. Posted April 17, 2007 Share Posted April 17, 2007 Carfax GENERALLY tells you why it's salvaged. Link to comment Share on other sites More sharing options...
redcoats1976 Posted April 17, 2007 Share Posted April 17, 2007 depending on who did the work it might be fine.i once worked in a restoration shop that took rusted out musclecars and made them better than new(sandblasted,stripped,new metal welded in,and all parts rebuilt or replaced) Link to comment Share on other sites More sharing options...
