CRXJerk Posted April 14, 2007 Share Posted April 14, 2007 The CRX started to make some noise in the front end so I stopped and checked it out. I started by pushing and pulling on the front left tire (towards and away from motor) and found that there was some play. I removed the tire and did the same to the break assembly and found that the axe is moveing slightly. I know that the axle isn't a structural part and is only there to spin the tire. My question is, what parts keep the axle where it is? Is it the tie rods? Upper control arm? Link to comment Share on other sites More sharing options...
cranny Posted April 14, 2007 Share Posted April 14, 2007 if your pushing and pulling on the top of the tire its most likely an upper balljoint. if you can pry apart the LCA and spindle at all , its a lower balljoint. make sure your axle nut is tight. Link to comment Share on other sites More sharing options...
CRXJerk Posted April 14, 2007 Author Share Posted April 14, 2007 Thank you, i'll give that a try. Link to comment Share on other sites More sharing options...
Hatch92 Posted April 14, 2007 Share Posted April 14, 2007 i'm gonna say wheel bearing or upper ball joint best way to find out is get the car off the ground and lay under it, have someone move the tire and see where it is moving from. if it is moving up and down it's a wheel bearing or ball joint. if it move just side to side it's a tie rod end or wheel bearing. if it moves in all directions you have alot of broke parts or a wheel bearing. hope that helps you out. Link to comment Share on other sites More sharing options...
crxtacy Posted April 15, 2007 Share Posted April 15, 2007 What kinda noise was it making? A growling noise ? Clunking noise ? Link to comment Share on other sites More sharing options...
CRXJerk Posted April 23, 2007 Author Share Posted April 23, 2007 clunky, although it hasn't done it in 2 days. Link to comment Share on other sites More sharing options...
