draybook Posted March 27, 2007 Share Posted March 27, 2007 I have a 91 CRX hf. The distributor has been giving me trouble lately. It will usually cause the car to idle rough when I slow down or when I'm at a stop, sometimes causing the car to stall. Usually I can get it cranked back up but if it happens 2 or 3 times during the same drive, it will drain my battery and I'll have to charge it back up. Sunday, this happened on my way to work so I left it at the gas station and came back for it after work. A friend tried to jump it off with his Jeep Wrangler, and after 10 minutes of us letting the cables charge my battery, nothing. It only gave me a click and no turn over or even an attempt. So, I ended up getting a friend with a strap and towing it to the house. I charged the battery all night and then today I tried it again. nothing but a click. I've used a fluke and all connections are getting over 12 volts, so they're good it seems. The battery is good as well. When I try to start it, it just gives out a click and all the interior lights dim a bit. I'm hoping it's not the starter since I have no money for one at the moment. I haven't tried push starting it because if it is the starter or something else, I won't be able to push start it every time I need to drive. Any ideas would be great. Link to comment Share on other sites More sharing options...
catawalks Posted March 27, 2007 Share Posted March 27, 2007 I have a 91 CRX hf. The distributor has been giving me trouble lately. It will usually cause the car to idle rough when I slow down or when I'm at a stop, sometimes causing the car to stall. Usually I can get it cranked back up but if it happens 2 or 3 times during the same drive, it will drain my battery and I'll have to charge it back up. Sunday, this happened on my way to work so I left it at the gas station and came back for it after work. A friend tried to jump it off with his Jeep Wrangler, and after 10 minutes of us letting the cables charge my battery, nothing. It only gave me a click and no turn over or even an attempt. So, I ended up getting a friend with a strap and towing it to the house. I charged the battery all night and then today I tried it again. nothing but a click. I've used a fluke and all connections are getting over 12 volts, so they're good it seems. The battery is good as well. When I try to start it, it just gives out a click and all the interior lights dim a bit. I'm hoping it's not the starter since I have no money for one at the moment. I haven't tried push starting it because if it is the starter or something else, I won't be able to push start it every time I need to drive. Any ideas would be great. Sounds like it could be the starter...or perhaps your clutch switch? check the clutch switch first since that is the easiest. Then I would try to pop start it to make sure it works. If you still have the rough idle I would check the distributor and plugs/wires. Maybe replace them. And then check the starter. If you can get it off yourself you can usually bring it to a place like autozone or maybe just your local shop and they can check to see if its malfunctioning or not. Where is your location btw. I have an HF sitting in my driveway that runs but the frame is rusted to crap. So I have extra parts...lol Link to comment Share on other sites More sharing options...
Kegger Posted March 27, 2007 Share Posted March 27, 2007 Well if the battery isn't charging while its running, you need to get your alternator tested as well as your battery. Link to comment Share on other sites More sharing options...
draybook Posted March 27, 2007 Author Share Posted March 27, 2007 I live in Southaven, MS, just across the state line from Memphis, TN. I could use another starter most likely. I also could use another dizzy but it would have to be from a 89 Teggy since my motor is a ZC. Link to comment Share on other sites More sharing options...
