brake master cylinder
ArtyMillz
ok im removing my master cylinder but i dont no to much about this.....so after i disconnect the brake lines and then i disconnect the mounting bolts...and when i pull it out t6is still connected to something do i just go under my dash and disconnect it from the brake pedal? or is there something else i need to do?
