flawless95 Posted February 21, 2007 Share Posted February 21, 2007 i have a 95 civic dx and i bought a b16a2. i need to know if there is any website that could tell me how to do the whole swap because i wanna do it myself not only to save the money but to learn . id aprecciate any suggestions as well. Link to comment Share on other sites More sharing options...
solmeistro Posted February 21, 2007 Share Posted February 21, 2007 make sure you have the b-series motormounts and exhaust. taking the motor out is pretty simple. take off your axels, starter, and alternator and lower motor mount and bracket on the bottom firewall in the middle. after that put a jack underneath the oil pan and undo all the motormounts, wiring harness clips, heater hoses, vacuum lines and ac lines. after that the motor will come right out and the knew motor will slip right in and reverse the removal process. just don't forget how you take things apart because they go back on the new motor the same way. Link to comment Share on other sites More sharing options...
flawless95 Posted February 22, 2007 Author Share Posted February 22, 2007 make sure you have the b-series motormounts and exhaust. taking the motor out is pretty simple. take off your axels, starter, and alternator and lower motor mount and bracket on the bottom firewall in the middle. after that put a jack underneath the oil pan and undo all the motormounts, wiring harness clips, heater hoses, vacuum lines and ac lines. after that the motor will come right out and the knew motor will slip right in and reverse the removal process. just don't forget how you take things apart because they go back on the new motor the same way. what do i do about the whole vtec thing cause mine doesn't have vtec. and i have a custom exhaust, doesn't the b16 manifold fit the d15 exhaust. if not then i'm goinna have to replace that part that connects them right? Link to comment Share on other sites More sharing options...
4D_Civic_doze Posted February 23, 2007 Share Posted February 23, 2007 .. Link to comment Share on other sites More sharing options...
