1994 TEG Posted February 19, 2007 Share Posted February 19, 2007 I have a 94' Integra LS it has 198,233 miles on the motor but most of the miles are highway miles. It is burning oil really bad. Does anyone have any clue what it could be and how i could get it to stop burning oil? If you could help me id really appricate it. thanks nick :help: Link to comment Share on other sites More sharing options...
Monty Posted February 19, 2007 Share Posted February 19, 2007 First I would try the stop leak oil stuff. If it still burns oil you've got something really wrong with your car and you need to fix it ASAP,...or get a new motor. Is it just burning oil or is it spraying it on the engine? Link to comment Share on other sites More sharing options...
1994 TEG Posted February 19, 2007 Author Share Posted February 19, 2007 i looked around on the block and that and couldnt see anything visible where it would be leakeing and that. I believe it is just burning it. Do you have any idea what it could be? And it has a really bad smell as well Link to comment Share on other sites More sharing options...
Kegger Posted February 19, 2007 Share Posted February 19, 2007 Probably valve stem seals, but it could also be a headgasket. And if its not those things its piston rings. Link to comment Share on other sites More sharing options...
1994 TEG Posted February 19, 2007 Author Share Posted February 19, 2007 ok man thanks for the help. If anyone else thinks its something else please reply i need 2 kno so i dont blow my motor. Thanks Link to comment Share on other sites More sharing options...
cranny Posted February 19, 2007 Share Posted February 19, 2007 if your car still has power , burns oil mostly when cold , its seals. if its losing power , and burns it during higher revs or under load , than its rings. its not a headgasket at all. Link to comment Share on other sites More sharing options...
Ben. Posted February 19, 2007 Share Posted February 19, 2007 Only time you should worry about the headgasket is if you've severely lost compression and you have water in your oil. Link to comment Share on other sites More sharing options...
cranny Posted February 20, 2007 Share Posted February 20, 2007 i just finished a head gasket not 20 minutes ago , your oil turns into cake frosting , lol. Link to comment Share on other sites More sharing options...
1994 TEG Posted February 20, 2007 Author Share Posted February 20, 2007 ok thanks guys. its when i punch it and get it up in RPMs that i smell it really badly. Is it a pain to change out rings. would i be better off just re-building it while i have it out? Link to comment Share on other sites More sharing options...
cranny Posted February 20, 2007 Share Posted February 20, 2007 if you wanna do it right , engine needs to be bored out till its true , pistons to match the holes with new rings and bearings. if you just wanna make it work ok again , take pistons out , recrosshatch cylinders , fire old but cleaned pistons in with new rings and run it. sounds like its your rings wearing out , not seals. Link to comment Share on other sites More sharing options...
1994 TEG Posted February 21, 2007 Author Share Posted February 21, 2007 ok thanks im sure what im doing yet looking at a new motor. im going to post a new topic asking opinions bc im not sure what to go with all i want is more power lol Link to comment Share on other sites More sharing options...
cranny Posted February 21, 2007 Share Posted February 21, 2007 get a B16A swap and go LSVTEC. Link to comment Share on other sites More sharing options...
