Guest evocivic Posted March 6, 2003 Share Posted March 6, 2003 a buddy of mine wants his axles replaced on his 97 civic. are they as easy as i am told. taking a bolt off and pulling it off? does anybody know? Link to comment Share on other sites More sharing options...
civicwagovan Posted March 9, 2003 Share Posted March 9, 2003 well you have to take off the caliper and rotor the you can take off the big bolt on the end, then you have to separate the bottom ball joint and then you can pull the end shaft out and the assembly will swing out of the way when your done withe that and the axle is hanging free get a flat head screwdriver and use it to pop the input end out of the tranny Link to comment Share on other sites More sharing options...
