forlife Posted November 17, 2006 Share Posted November 17, 2006 I don't know what's going on... About every thousand miles I have to add a quart of oil. The weird thing is that I have no white smoke coming from the exhaust, and my driveway is clean, no oil drippage anywhere. Does anyone know what's going on??? Link to comment Share on other sites More sharing options...
chris(pa) Posted November 17, 2006 Share Posted November 17, 2006 I think you might have a oil problem But really, this is veryyy vague Link to comment Share on other sites More sharing options...
forlife Posted November 17, 2006 Author Share Posted November 17, 2006 I just don't know where to start... Head gasket maybe, that's all I can think of... Compression tests??? Could I have a small enough amout of white smoke that I wouldn't see it, but enough to burn a quart of oil every thousand miles? Link to comment Share on other sites More sharing options...
chris(pa) Posted November 17, 2006 Share Posted November 17, 2006 what car? engine? mods? miles? Link to comment Share on other sites More sharing options...
forlife Posted November 17, 2006 Author Share Posted November 17, 2006 I just don't know where to start... Head gasket maybe, that's all I can think of... Compression tests??? Could I have a small enough amout of white smoke that I wouldn't see it, but enough to burn a quart of oil every thousand miles? 99 Accord LX, no mods, 134,000 miles. It was my parents and they drive very... well like grandparents. So the car's been babied. Link to comment Share on other sites More sharing options...
chris(pa) Posted November 17, 2006 Share Posted November 17, 2006 check the engine for any oil if there isnt any, cry or take it to a mechanic its impossible to tell what is wrong over the intraweb with such a vague topic Link to comment Share on other sites More sharing options...
forlife Posted November 17, 2006 Author Share Posted November 17, 2006 99 Accord LX, no mods, 134,000 miles. It was my parents and they drive very... well like grandparents. So the car's been babied. Ok, thanks though Link to comment Share on other sites More sharing options...
Huffa Posted November 17, 2006 Share Posted November 17, 2006 Take note in the morning when you 1st start it to see if you are getting any Blackish - Blueish smoke coming out of the exhaust and if their is some it is a good idication you might have worn valve guide seals. With seals it will only do it in the morning and maybe at the end of a 8 hour work day. Once up to operating temp the valve guide seals may seal a little better and the cat will be hotter and burn the excess off so you would not see any. A compression test will give you a good ring - valve seal story, so you might want to ave that done too. Burning oil does not make white smoke come out, that would be a head gasket failure most likely. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted November 17, 2006 Share Posted November 17, 2006 oil burning is a blue. plus your cat doesn't "burn" anything....It is a simple reaction. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 18, 2006 Share Posted November 18, 2006 I don't know what's going on... About every thousand miles I have to add a quart of oil. The weird thing is that I have no white smoke coming from the exhaust, and my driveway is clean, no oil drippage anywhere. Does anyone know what's going on??? i'm gonna say prolly a set of rings goin bad. or valve stem seals Link to comment Share on other sites More sharing options...
