92ge Posted October 30, 2006 Share Posted October 30, 2006 ok so i took my car out for a spin around the block...it was driving fine until my underdrive crank pully fell out and was lying on the grass...sucks a$$...the belt to the alternator is missing and i can still start the engine but it makes a wierd noise...can i buy a new chuck key and the bolt and put the pully back in and will it be the same...or did i mess up my crank?... Link to comment Share on other sites More sharing options...
AckNasty Posted October 31, 2006 Share Posted October 31, 2006 Wow! Don't drive it. The underdrive crank pulleys are bad b/c they dont have a harmonic balancer built in. It reduces harmful vibrations in crank. I'd put the stock pulley back on and make sure the bolt is tight! Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2006 Share Posted October 31, 2006 130 ft/lbs that bolt goes. fire OEM pully back on , tighten bolt , fire new alt belt on , away you go dude. that didnt hurt it. shouldnt have. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 31, 2006 Share Posted October 31, 2006 ok so i took my car out for a spin around the block...it was driving fine until my underdrive crank pully fell out and was lying on the grass...sucks a$$...the belt to the alternator is missing and i can still start the engine but it makes a wierd noise...can i buy a new chuck key and the bolt and put the pully back in and will it be the same...or did i mess up my crank?... uuuuhh.....the crank pully came off and you can still start the car? ooook Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2006 Share Posted October 31, 2006 that pully is for accessorys dude , not needed to run an engine. your gonna need a new keyway sounds like as well , the little keyway that goes between the pully and the crank in the little groove. your gonna need one. Link to comment Share on other sites More sharing options...
92ge Posted October 31, 2006 Author Share Posted October 31, 2006 yep...i got everything...but waiting for the bolt...but it makes a wierd noise without the crank pully (like a clicking noise)....will that noise go away once i put everything back together.... Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2006 Share Posted October 31, 2006 its also a balancing tool for your crankshaft as its turning. thus the name harmonic balancer. older cars , or domestic V8's for the most part anyways , have a harmonic balancer , than the main pully bolted to that. well in your car , they are 2 in 1. see what happens when you bolt it back on , than post results , all you can do my man. i really cant see it hurting the engine. i hope your bolt just came out and didnt break off inside as well , lol , thats a crap ass job to do , even with a good easy out. Link to comment Share on other sites More sharing options...
92ge Posted November 1, 2006 Author Share Posted November 1, 2006 nope...the bolt did not break off in there...but the slot where the key goes into is kinda stripped...is there a way to keep that pully in there...could i weld it into place...? Link to comment Share on other sites More sharing options...
92ge Posted November 1, 2006 Author Share Posted November 1, 2006 ok...so this morning i put the carnk pull back on with the key...it wobbles a bit...but will it go away once i put the bolt back in there....? could i weld the bolt right in there so it wont fall out next time...? Link to comment Share on other sites More sharing options...
cranny Posted November 1, 2006 Share Posted November 1, 2006 i wouldnt do that. where is the keyway slot stripped , pully? or crank? Link to comment Share on other sites More sharing options...
92ge Posted November 1, 2006 Author Share Posted November 1, 2006 on the crank...the pully is in good condition...wat should i do....? Link to comment Share on other sites More sharing options...
cranny Posted November 2, 2006 Share Posted November 2, 2006 hmmm. get it to fit as best as possible dude. i mean the bolt will hold it tight , but make sure its sitting where it has to be before its tightened. weld the keyway to the crank if you have to. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 2, 2006 Share Posted November 2, 2006 that pully is for accessorys dude , not needed to run an engine. your gonna need a new keyway sounds like as well , the little keyway that goes between the pully and the crank in the little groove. your gonna need one. ahh look learned somethin new. Link to comment Share on other sites More sharing options...
92ge Posted November 2, 2006 Author Share Posted November 2, 2006 well i just put the bolt into place...it runs great now...will the bolt come off again...? and if it does wat are some things that i can do to help prevent it from happening next time... Link to comment Share on other sites More sharing options...
cranny Posted November 3, 2006 Share Posted November 3, 2006 easy , tighten it to the right torque. 130 ft/lbs. Link to comment Share on other sites More sharing options...
