ArtyMillz Posted October 30, 2006 Share Posted October 30, 2006 everytime i shift my car back fires not loud but u can clearly hear it....does anyone no what causes this problem? Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 30, 2006 Share Posted October 30, 2006 everytime i shift my car back fires not loud but u can clearly hear it....does anyone no what causes this problem? exhaust leak Link to comment Share on other sites More sharing options...
sonnyjc3 Posted October 30, 2006 Share Posted October 30, 2006 exhaust leak urmz. octane booster is your new best friend <3 Link to comment Share on other sites More sharing options...
FiRe_OpTiKz© Posted October 30, 2006 Share Posted October 30, 2006 no it's called back pressure when your car revs right around 3. - 5 grand your backprssure builds and thats what causes your motor to backfire or Misfire it's not a bad thing. my hatch does it and it's built i just need a turbo because im running so low of a compression that it does have the back pressure power to keep the air flowing correctly Link to comment Share on other sites More sharing options...
cranny Posted October 30, 2006 Share Posted October 30, 2006 you have low compresison pistons in your car with no turbo? your car must have zero balls dude , lol Link to comment Share on other sites More sharing options...
FiRe_OpTiKz© Posted October 30, 2006 Share Posted October 30, 2006 actually i do 115 in third my motor is built not just have low compression pistons..lol Link to comment Share on other sites More sharing options...
Kegger Posted October 31, 2006 Share Posted October 31, 2006 It's prolly cuz you're running a little rich or your ignition timing is advanced just a tad bit too far. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 31, 2006 Share Posted October 31, 2006 actually i do 115 in third my motor is built not just have low compression pistons..lol and that little motor is screamin isn't it? Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2006 Share Posted October 31, 2006 its backfiring most likely , cause you have too low of compression to run without boost. Link to comment Share on other sites More sharing options...
FiRe_OpTiKz© Posted October 31, 2006 Share Posted October 31, 2006 no my motor is pretty quiet. Link to comment Share on other sites More sharing options...
GElite Posted November 1, 2006 Share Posted November 1, 2006 My 92 Civic Hatch backfires a little bit between each shift. It has a B18B1 LS VTEC conversion in it with a custome exaust and no catalitic converter. Its running a little rich and the rings are about shot. All perfect condtions for un-burned fuel to be in the exaust but any one of those conditions by its self could cause it. There are so many diffrent things that could cause it. Your thermo sensor could be bad which causes the car to run rich n order to make it run hotter. When the sensor goes bad it thinks that the car is running cooler than it actually is. Link to comment Share on other sites More sharing options...
