92ge Posted October 9, 2006 Share Posted October 9, 2006 hey guys, i just bought a 92 hatch with a jdm d15b motor swap. everything on it is great, but the only thing that is wrong is that it's not getting spark or no fuel is getting to the engine? i believe the no spark is the distributor cap, but not sure about the fuel problem...if anyone knows a solution, please let me know ASAP.... Link to comment Share on other sites More sharing options...
koffeeDC2 Posted October 9, 2006 Share Posted October 9, 2006 when you turn the key to the on position do you hear the fuel pump make a noise Link to comment Share on other sites More sharing options...
92ge Posted October 9, 2006 Author Share Posted October 9, 2006 i don't think so...it cranks, but no fuel...i know of that sound that you are talking about, but i don't seem to hear it...do you think it's because of the fuel pump?...is that hard to replace in this year civic? Link to comment Share on other sites More sharing options...
koffeeDC2 Posted October 9, 2006 Share Posted October 9, 2006 it could be the fuel pump but you might wanna check all your fuses first just to make sure. i have never dropped the gas tank in a honda but it cant be too hard just hope its not full Link to comment Share on other sites More sharing options...
xer0 Posted October 9, 2006 Share Posted October 9, 2006 after u check fuses on hook your fuel filter( with teh car off). epty out the filter so u kno it is try then hoock it back up turn the car ova pump gas. then see if any fuel got to the filter. jsut so you kno if it si a problem before of after filter Link to comment Share on other sites More sharing options...
92ge Posted October 9, 2006 Author Share Posted October 9, 2006 im guessing that it is just the distributor cap because the same thing happened to my accord and when i relpaced it, it ran fine...i don't know if that will get any fuel to the car, but its worth a try... Link to comment Share on other sites More sharing options...
mikedahndaking Posted October 10, 2006 Share Posted October 10, 2006 ya i would check your distributor but more than likely its your fuel pump my car had the same problem when i got it and taking the gas tank down isn't to hard Link to comment Share on other sites More sharing options...
Hatch92 Posted October 10, 2006 Share Posted October 10, 2006 do have the stock steering wheel or did u replace it. if u replaced it u might have triggered the fuel shut off Link to comment Share on other sites More sharing options...
civic28236 Posted October 10, 2006 Share Posted October 10, 2006 also before you drop tank may sure there is no under seat access just make sure or back in the hatch area Link to comment Share on other sites More sharing options...
Hatch92 Posted October 11, 2006 Share Posted October 11, 2006 also before you drop tank may sure there is no under seat access just make sure or back in the hatch area WTF?!?!? i have no clue what u said.... Link to comment Share on other sites More sharing options...
mycarsux Posted October 11, 2006 Share Posted October 11, 2006 also before you drop tank may sure there is no under seat access just make sure or back in the hatch area Link to comment Share on other sites More sharing options...
xer0 Posted October 11, 2006 Share Posted October 11, 2006 He just was saying there may be a way to get to your tank, ether under the. seat or in the trunk. Any smart person can decipher stupidity, how do you think i can read your post mycarsux? Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted October 11, 2006 Share Posted October 11, 2006 oooooooooooooh well wen i want to c if i am getting spark i just take a wire out and put it close to the block and have some one crank it if theres spark or a clickin sound. then for fuel i just take a spark out then open the switch and press the gas and use my nose. but dont use this methods this are for dum asses. Link to comment Share on other sites More sharing options...
rapperbasher Posted October 12, 2006 Share Posted October 12, 2006 i had the same problem and it could be a pgm-fi relay as well... Link to comment Share on other sites More sharing options...
