Si_EcKO Posted October 3, 2006 Share Posted October 3, 2006 hopefully im not tha only one that has this problem but when i press the switch to put my window up right before it reaches the top it starts doin this rattle noise and tha window start movin up and down at tha same spot...and it wont close....so if anyone know anything please lemme kno...thanks Link to comment Share on other sites More sharing options...
Humphries Posted October 3, 2006 Share Posted October 3, 2006 same here.. the window came off the track and is not going up as it should. take the door panel off using a 10 mm socket and ratchet, and a phillips head screwdriver for the five screws. just put the window back on track and then tighten it up a lot more. if this is nothing about what happened with you.. then that sucks.. in case you want to take off your door panel, heres some instructions.. well halfass ones anyhow. Link to comment Share on other sites More sharing options...
cranny Posted October 3, 2006 Share Posted October 3, 2006 you have teeth missing or broken on the actuator inside the door. take the skin off , look inside door , theres 2 arms that come together on this gear that is tooth driven. hard to explain , take it apart youl see. common in those cars , keep the sliders lubed and it wont happen. Link to comment Share on other sites More sharing options...
spyder_Si Posted October 3, 2006 Share Posted October 3, 2006 I had the same problem with it jumping off track. it turned out to be the weather striping. look at that and see if it is damaged at all. Link to comment Share on other sites More sharing options...
Humphries Posted October 3, 2006 Share Posted October 3, 2006 yeah my stripping is damaged a little bit.. i'd like to have new ones but im out of funds. Link to comment Share on other sites More sharing options...
Si_EcKO Posted October 3, 2006 Author Share Posted October 3, 2006 Ima bout to order and new regulator and a motor on ebay would that fix the problem???and about the window sliding out the tracks,i didnt kno bout that lube thing ima try that cause both right and left side r doin it and i cant say how many time i took off tha panel and tighten that crap but thanks fellas Link to comment Share on other sites More sharing options...
spyder_Si Posted October 4, 2006 Share Posted October 4, 2006 dude before you spend all that money check the weather stripping!!!! Thats what my problems was. and the stripping fixed it havent had trouble since. Link to comment Share on other sites More sharing options...
