draybook Posted September 25, 2006 Share Posted September 25, 2006 So, a few nights ago, my CRX started sputtering and the engine light flickered off and on. The car would start after the first or second try but would again sputter and flicker and then die. I was able to get it home and let it sit. My brother in law was able to come look at it and we found that the main relay was only getting 10 volts, thus explaining the sputtering and flickering. So, he tinkers with it for a bit and he's able to solve the problem of the voltage shortage but now there's a new problem. Now, the main relay won't kick power to the fuel pump. It can be bypassed and will kick on but now it won't turn over at all. So, I'm looking for any help I can get as to what anyone thinks it might be. My father in law is looking at it since he's great with most cars and with electrical stuff, but he's not too experienced with imports. My brother in law is great mechanically with imports, just not with most electrical stuff. If anyone can throw me some ideas, that would be great, thanks. Just for the record, it's a 1991 CRX, running a DOHC ZC motor, with a 14b turbo. We've checked it with another relay and it works, so does the ECU/CPU. It's getting fuel and spark also. Link to comment Share on other sites More sharing options...
mycarsux Posted September 26, 2006 Share Posted September 26, 2006 EDIT: scratch that. If you're getting fuel the how is your fuel pump not working? When your brother in law played with the relay he may have blown a fuse to the fuel pump, check it. Link to comment Share on other sites More sharing options...
draybook Posted September 26, 2006 Author Share Posted September 26, 2006 I meant that when you bypass it, it will get fuel. However, I don't understand why it will work if you bypass the relay and not when you straight shot it through the relay. I'm going to try another relay just to make sure. Link to comment Share on other sites More sharing options...
Kastigir Posted September 26, 2006 Share Posted September 26, 2006 Are you serious? Replace the relay. Link to comment Share on other sites More sharing options...
mycarsux Posted September 26, 2006 Share Posted September 26, 2006 I'm going to try another relay just to make sure. Link to comment Share on other sites More sharing options...
Kastigir Posted September 27, 2006 Share Posted September 27, 2006 Actually, that was in response to this. Just for the record, it's a 1991 CRX, running a DOHC ZC motor, with a 14b turbo. We've checked it with another relay and it works, so does the ECU/CPU. It's getting fuel and spark also. If it works with one relay, but not the other, you'd think that 2+2=4. Apparently not where he comes from. Link to comment Share on other sites More sharing options...
draybook Posted September 28, 2006 Author Share Posted September 28, 2006 Actually, that was in response to this. If it works with one relay, but not the other, you'd think that 2+2=4. Apparently not where he comes from. I meatn that the other relay has power and also gives power to everything but the fuel pump. But thanks for trying to be a smartass. Only took you like 4 days to come up with that witty retort. Anyhow, I've been able to bypass the relay with a toggle switch for the fuel pump, but that's just a quick ghetto fix. Hopefully I can get it fixed for good soon. Link to comment Share on other sites More sharing options...
mycarsux Posted September 28, 2006 Share Posted September 28, 2006 But thanks for trying to be a smartass. Only took you like 4 days to come up with that witty retort. Anyhow, I've been able to bypass the relay with a toggle switch for the fuel pump, but that's just a quick ghetto fix. Hopefully I can get it fixed for good soon. .pwned. Glad to hear its working, dude. Link to comment Share on other sites More sharing options...
draybook Posted September 28, 2006 Author Share Posted September 28, 2006 Yeah, I bypassed it with a toggle switch, which is what my brother in law planned on doing anyways, and it runs fine. Now I have time to figure out what's wrong between the cpu and the main relay. Link to comment Share on other sites More sharing options...
Kastigir Posted September 29, 2006 Share Posted September 29, 2006 Yeah, I bypassed it with a toggle switch, which is what my brother in law planned on doing anyways, and it runs fine. Now I have time to figure out what's wrong between the cpu and the main relay. Until you burn something up. Things are meant to work one way for a reason. You're probably pushing too much/not enough current and most likely will burn something out if you keep it wired the way it is for too long. Good luck with that. Link to comment Share on other sites More sharing options...
