civic1 Posted September 22, 2006 Share Posted September 22, 2006 wut is the easiest way to lean down the air fuel ratio in a 94 civic motor. it is running extremely rich and i need the problem fixed as soon as possible. any help. thanks Link to comment Share on other sites More sharing options...
mycarsux Posted September 22, 2006 Share Posted September 22, 2006 Didn't you just get arrested for racing? Shouldn't you have your license revoked? Whatever... New injectors might do the trick? Idk what size is good, sry. An IM maybe, fpr, fuel mods, an ecu by hondata (not a chipped one). Idk dude the list in endless. Get a wideband gauge too if you don't have one. Tells you A/F ratio. That's always helpful. Link to comment Share on other sites More sharing options...
civic1 Posted September 23, 2006 Author Share Posted September 23, 2006 it wont get suspended till at least my court date wuch is in a month Link to comment Share on other sites More sharing options...
sloassrex Posted September 23, 2006 Share Posted September 23, 2006 Maybe your injectors are dripping, get them cleaned, or use some injector cleaner that goes in your gas tank. Hopefully that will do the trick. Link to comment Share on other sites More sharing options...
RazorbackMustang Posted September 23, 2006 Share Posted September 23, 2006 Check for exhaust leaks as well. Link to comment Share on other sites More sharing options...
b16a1CRXSiR Posted September 23, 2006 Share Posted September 23, 2006 it could also be caused by a failing sensor (i.e. TPS, MAP, IACV, etc.) Link to comment Share on other sites More sharing options...
civic1 Posted September 24, 2006 Author Share Posted September 24, 2006 alright thanks for the help Link to comment Share on other sites More sharing options...
