spinal Posted September 5, 2006 Share Posted September 5, 2006 OK I have a 99 Accord 4Dr.. I had it lowered with sprint springs and camber kit.. the whole 9... Anyway!! I spent all weekend removing the lowered springs and replacing them with the entire OEM setup (reason is i'm trading it in) After everything was installed and double checked I drove it and the rear is swaying.. kinda hard to keep it on the road. I need some advice on what could be causing this? I'm thinking maybe when i put the OEM rear lower control arms back in I might have put them in backwards... I know they look excactly the same but if you really look one end of the arm is alittle bigger then the other.. I Dunno!! PLxz HELP!!! Link to comment Share on other sites More sharing options...
